Re: fuel issues posted by Bo (houston) on June 05, 2011 at 03:08 PM
thnks for the advice. still gotta check voltage. the pump started humming faintly for a few trys then stoped again. Also i am 99.9% sure the fuel lines r right but i will def check. if it is a control unit how would i test for that? they were working before injector change car was running before torn apart just running rough. any advice will help. i need her running! also could a faulty fuel pressure regulator contribute to this issue? Please help!
